3 Wire serial lcd [ 74HC595 and LCD]
Jestin_cubetech
Advanced Member level 1
3 Wire serial LCD [ 74HC595 and 20X4 LCD]
                   //4bit lcd mode
#define L_SCK RD0   //LATCH CK
#define S_SCK RD1  //SHIFT CK
#define SDO   RD2  //DATA OUTPUT
#define LATCH  L_SCK=1;  L_SCK=0;
#define SHIFT  S_SCK=1;  S_SCK=0;
void serial_lcd(unsigned char val)
for(char i=0;i<8;i++)
 SDO=(val&0X80)>>7; val<<=1;   //LSB  lcd control pins    and   MSB Lcd data pins
 SHIFT;
 LATCH;
void lcd_send(unsigned char type,unsigned char val)	  //type 0=command 1=data  lcd value
   serial_lcd(type|(val&0xf0));            //Set RS  and Data
   serial_lcd(0x04|(val&0xf0));            // EN=1   and Data
   serial_lcd(type|(val&0xf0));            //EN=0    and Data
   serial_lcd(type|((val<<4)&0xf0));    //Set RS  and Data
   serial_lcd(0x04|(val<<4)&0xf0);      // EN=1   and Data
   serial_lcd(type|((val<<4)&0xf0));    //EN=0    and Data
Jestin_cubetech, please send the all code of your 3 Wire serial LCD [ 74HC595 and 20X4 LCD]!!!
Thanks.
