walters
Advanced Member level 2
I'm trying to use a DVM meter in ohm mode to check transistors and mosfets in circuit
All I get is resistance measurements in the Meg ohms
Is there any other way to check or test transistors or mosfets in circuit?
Cause I can't make head or tails if they are open since its reading in the meg ohm or if it's shorted because of the resistance reading
The problem I'm having is that There is a SHORT or Multiple Shorts on PCB board circuits at my work and I'm trying to check the transistors and mosfets in the power supply section
The SHORTS causes the resistance readings to be different on every PCB board I check
I have Written down the resistance readings off of a GOOD working board a KGB, to reference off of.
But that doesn't do any good, why? because the transistors and mosfets can still be operating fine even if the resistance is way off because the SHORT somewhere on the PCB boards has changed the resistance value
So I have no Idea if the transistors or mosfets are GOOD or NOT , cause i can't make heads or tails because the SHORTS have changed everything
I'm just trying to verify if the transistors and mosfets work
How can I do this please?
