walters
Advanced Member level 2
How to find SHORTS or Shunts in a circuit
1.) You measure the voltage drop across the resistor and convert it to current.
2.) You compare the current value with the supply voltage?
3.) If it's a SHORT or shunt would the current value be zero or very HIGH?
3volt supply feeding a 10mega resistor , the voltage drop is 2.62volts across the resistor, the current would be 2.62picoAmps its PICOamps right?
