PIC18F4523 ADCON2 Configuration
ADCON2 is basically a analog port selection register. by this register you can select the analog and digital inputs of the multiplexed pins.
You are wrong. ADCON2 in PIC18F4523 is used to set the acq time.
    rafeeqmpm
These values are dependent on several factors, including system clock frequency (Fosc), the number of bits and operating temperature.
The Acquisition Time and Conversion Time refer to two very different time periods.
What is the Fosc, the desired number of bits in the ADC and maximum operating temperature of the design?
BigDog
    rafeeqmpm
I don't know about TAD. Please explain it clearly. I am using ext hs osc 20 Mhz. I am trying to implement adc routine in asm and I want to know every detail about adc. https://ww1.microchip.com/downloads/en/devicedoc/39755a.pdf Page 229
My Fosc is 20 MHz
Tad = x/Fosc where x = 2, 4, 8, 16, 32, or 64
if x = 2, Tad = 0.1us
x = 4, Tad = 0.2us
x = 8. Tad = 0.4us
x = 16, Tad = 0.8us
x = 32, Tad = 1.6us
x = 64. Tad = 3.2us
Tcy = 1/Fosc = 1/20 MHz = 0.05us = 50ns
Tosc is 1/(Fosc/4) = 1(20 MHz/4) = 1/5 MHz = 0.2us
The datasheet says, assuming minimum Tad = 0.8us, for 20 MHz Fosc, Tosc = 16Tosc
16Tosc = 16 * 0.2us = 3.2us.
Tacq = 2.96us mentioned in http://ww1.microchip.com/downloads/en/devicedoc/39755a.pdf page 232 last part
Am I right?
Just give me an example for 20 MHz Fosc. What should be the value of ADCON2? I'm using PIC18F4523, 12-bit ADC.
What should be ACQT2-ACQT0 and ADCS2-ADCS0?
All I know is this,
The following steps should be followed to perform an A/D
1. Configure the A/D module:
• Configure analog pins, voltage reference and
digital I/O (ADCON1)
• Select A/D input channel (ADCON0)
• Select A/D acquisition time (ADCON2)
• Select A/D conversion clock (ADCON2)
• Turn on the A/D module (ADCON0)
2. Configure the A/D interrupt (if desired):
• Clear ADIF bit
• Set ADIE bit
• Set GIE bit
3. Wait the required acquisition time (if required).
4. Start conversion by setting the GO/DONE bit
(ADCON0<1>).
5. Wait for the A/D conversion to complete by either:
• Polling for the GO/DONE bit to be cleared
OR
• Waiting for the A/D interrupt
6. Read the A/D Result registers (ADRESH:ADRESL)
and clear the ADIF bit, if required.
7. For the next conversion, go to step 1 or step 2,
as required.
The A/D conversion time per bit is defined as
TAD. A minimum wait of 2 TAD is required before
the next acquisition starts.
but I need some help in implementing adc routine in asm.
