internetuser2k11
Banned
In my circuit LM35 is connected to ADC0804 and o/p of ADC 0804 (D0-D7) is connected to P0 of 89S52.
WR of 0804 is connected to P3.6, RD of 0804 to P3.7 and INTR of 0804 to P3.2. The following code is giving some 13.9999 as the output. What is wrong in the code. I'm trying to read LM35 into ADC 0804 and then place the o/p of 0804 @ P0 of 89S52, and then display P0 value on lcd.
[syntax = mikroC]
#define high 1;
#define low 0;
// LCD module connections
sbit LCD_RS at P3_4_bit;
sbit LCD_EN at P3_5_bit;
sbit LCD_D4 at P2_4_bit;
sbit LCD_D5 at P2_5_bit;
sbit LCD_D6 at P2_6_bit;
sbit LCD_D7 at P2_7_bit;
// End LCD module connections
int temp_limit;
float adc_val;
char myStr[23];
void main() {
Lcd_Init();
Lcd_Cmd(_LCD_CURSOR_OFF);
Lcd_Cmd(_LCD_CLEAR);
Lcd_Out(1,1,"89S52 and LM35 Based");
Lcd_Out(2,1,"Temperature Monitor");
delay_ms(2000);
temp_limit = 27;
do {// Function for A-D conversion
P3_6_bit = low; //WR = 0
P3_6_bit = high; //WR = 1
if (P3_2_bit == 0) { //INTR of 0804 = 0?
P3_7_bit = low; //RD = 0
adc_val = P0; //0804 [D0-D7] = P0 [89S52]
FloatToStr(adc_val, myStr);
Lcd_Out(2,1,myStr);
if (adc_val > temp_limit) {
P1_1_bit = 1;
else {
P1_1_bit = 0;
} while(1);
[/SYNTAX]
