Robert T
Member level 1
![Member level 1](/styles/images/ranks/dlevel1.gif)
I have a project which is detecting the amplitude of the return signal of an RF tag. The RX antenna is a separate antenna.
The issue I am having is being able to read the RX signal as close as possible to the TX switching off. The ring down for the TX is too long - 600 us - so I am looking to short the antenna using a switch.
I have tried using a RF transistor - TIP48 - and mostfets but when the TX is on, these seem to short to ground. The voltage on the TX is 200V peak to peak.
Frequency is 58 kHz.
Can anyone suggest a means that I can shunt the ring down signal or short the antenna.
Thank you.
Thank you.
