The 24VDC is from truck or car battery.I want to have a robust input circuit to overcome typical noises in automative and protects against voltage spikes.
Generally you put TRANSIL diodes for protect over voltage (between line and ground), in series before transil you put PTC resistors for protect over current. After this you put choque and capacitors for do the filter ...
24V systems are composed by two series 12V bateries ...
