24V 20AH SLA Battery charger..
vishnukarthick108
Newbie level 2
Newbie level 2
Vellore, Tamil Nadu
this is a circuit i got from a forum, and please help me to simulate it in software, which software will be good, and what does the E in resistor represents, how shall i take those 0.1E,5watt resistor in that software, and also please tell me what output should i get at the terminal of battery (i'm now trying in multisim),some components are not available as it is in circuit...
please suggest me a good solution, if some other circuit available pls give me...
E in the circuit diagram stands for "ohms"
normally R is used to designate ohms in a schematic
27V dc at the output should be all right for charging
Use Proteus for simulation
Google (Image) and you will find a lot of circuits
You can use PSpice to simulate this circuit. You can download free PSpice unlimited evaluation version from **broken link removed**
You do not need to worry about power rating of devices in simulation, as these will never blow up :)
You all you need to add is 0.1 Ohm resistor, that is place a resistor in circuit, connect is as desired and change it's value to 0.1
sir, i have attached my simulation part with this... please help me....
  • ckt.doc
  • Circuit1 multisim file.rar
