stoyanoff
Full Member level 4
I want to use a product and in it`s datasheet the manifacturer was drown the chart from the pdf. This is a cirquit for current measurement. I`m not if it`s working because the voltage I`m going to measure and the supply voltage hasn`t common ground. So I think the amplifier will not change it`s output.
Is that true or the chart is fine???View attachment sheme.pdf
