bobdxcool
Member level 5
- Joined
- Mar 9, 2012
- Messages
- 82
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 2,042
this is the circuit i'm planing to use to generate some msic using 8051..
pls tell me whether any other modifications are needed?
this is the program written!
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 #include<reg51.h> sbit out=P1^0; //output pin 1 void delay(unsigned char p,unsigned char q) { TMOD=0x01; //timer0 mode1(16 bit) TL0=q; //load TL0 TH0=p; //load TH0 TR0=1; //turn on T0 while(TF0==0); // wait for flag generation TR0=0; // turn off T0 TF0=0; // clear TF0 } void play(unsigned char j,unsigned char k) { int i; for(i=0;i<1000;i++) //to play sound { out=1; delay(j,k); out=0; delay(j,k); } } void main() { int l; while(1) { play(0xfc,0x66); //playing sound of frequency of about 500 hertz with a delay between two frequencies for(l=0;l<5;l++) { delay(0x00,0x00); //delay of 71 miliseconds } play(0xfe,0x33); //playing sound of frequency of about 1000 hertz with a delay between two frequencies for(l=0;l<5;l++) { delay(0x00,0x00); } play(0xff,0xa3); //playing sound of frequency of about 5000 hertz with a delay between two frequencies for(l=0;l<5;l++) { delay(0x00,0x00); } play(0xff,0xd1); //playing sound of frequency of about 10000 hertz with a delay between two frequencies for(l=0;l<5;l++) { delay(0x00,0x00); } play(0xff,0xdc); //playing sound of frequency of about 13000 hertz with a delay between two frequencies for(l=0;l<5;l++) { delay(0x00,0x00); } play(0xff,0xcc); //playing sound of frequency of about 9300 hertz with a delay between two frequencies for(l=0;l<5;l++) { delay(0x00,0x00); } play(0xff,0xe8); //playing sound of frequency of about 20000 hertz with a delay between two frequencies for(l=0;l<5;l++) { delay(0x00,0x00); } } }
