W_Heisenberg
Full Member level 4
I think via is between metals
contact is metal and other non-metal things.
is this correct?
is this correct?
Contact is connection to source, drain or poly. While vias is used to make connection between two metal layers. Both vias and contact are formed using metals. Vias are generally made of tungsten while contact is made using aluminum.
is this correct?
