Electronic counter displays wrong count of the web on the roller
danishdeshmuk
Advanced Member level 1
Electronic counter displays wrong count of the web on the roller ....
LCM 60
if the current count is 10 it displays about 30 ..... i think it needs calibration .. what do you think ?
But how to calibrate it ? OR may it be another problem ?
-measuring what ??
-measuring principle is ??
-have you any name of device manufacturer and type ??
LCM 60 tells nothing to me.
www.cet-italy.it/italy/software/_fogli_istruzione/lcm60_en.pdf
CET VISUALIZED DIGITAL TOTALIZER
---------- Post added at 04:03 ---------- Previous post was at 04:01 ----------
The LCM 60 counter finds application where there is the
necessity to visualize mono-directional counts deriving
from electromechanical and logical contacts, proximity
and encoder.
1. Check that counter input sensor gives all the sensed and good quality pulses to count input.
- use oscilloscope to check pulse quality and level
-check inhibit signal, if inhibit is on , counter do not add counter input pulses
-if possible use parallel connected counter to check counted pulse number
2. If you are sure these two things are ok , check parameter settings.
-Input Fast - Slow.
-multiplier n1 and n2
External wiring for LCM60....
How to check parameter settings Input Fast - Slow & multiplier n1 and n2 ?
How to check inhibit signal ?
thanks
Everything is told in attached PDF with post #3
FRONTAL KEYBOARD DESCRIPTION
INPUT / OUTPUT DESCRIPTION
PROGRAMMING OF THE OPERATION PARAMETERS
PROGRAMMAZIONE DEI PARAMETRI DI FUNZIONAMENTO
OPERATION DIAGRAMS
CONNECTIONS & INPUT SIGNALS
Check with scope connector 6 = GND and connector 9 = signal Inhibit
what it should show (the scope) & what it shouldn't ?
the machine operator says that it always displays more counts than the actual ones ...... should check its parameters ?
thanks
1. Measure voltage between connector points 5 - 6
(6)= 0Vdc , (5) = +24Vdc +/- 20%
2. measured count pulses in point 7 should be in range (voltage in point 5) +0...-20%
-all pulses should have equal voltage and "sharp edges".
3. If parameters are not changed by somebody, there should be some fail in counted pulses.
-check from where the pulses are generated ( is there any proximity sensor for
sending count pulses , check is adjusting there correct )
4. If you must change parameters ,
remember to write down the original values first.
( parameters n1 and n2 are counter multipliers )
yeah there's a sensor , i think its a proximity sensor
The name of the sensor is Magnetschalte 100 VA, 250 v , 2A ... Typ GMS 9
Heinrich Kubler AG baar
025340
---------- Post added at 22:49 ---------- Previous post was at 22:45 ----------
Magnetschalter 100 VA, 250 v , 2A ... Typ GMS 9
025340
There are only 4 wires connected to the LCM 60 counter
at terminal 3 : 110 VAC
at terminal 4 : 0 VAC
at terminal 5 : + 24 Vdc 80mA
at termial 7 : Input
and its selected in pnp configuration ....
Now how to check the inhibit signals & other things to be checked which you mentioned in the above post ? Should i follow the same steps & the same patterns in this condition , as you mentioned above ?
thanks
This sensor is Magnetic Proximity Switch ,
active switching element is reed-switch.
Sensor is 2-wire type , connected between terminals 5 and 7
It is typical when they get older, this type of switch can give the uncertain
contact and thus cause a false pulse number
- bad contact = too low pulse number
- contact vibrating = too high pulse number
KSR Kuebler Catalog 1008....
General info in pages 3...6
Kuebler GMS 9 in page 9
http://www.ksr-usa.com/download/1008.pdf
If there is only 5-7 connected , check only count pulses ( 6 - 7)
and 24Vdc supply (5-6)
pnp configuration is right.
I guess bad contacts ( vibrating ) , so i would replace sensor.
As i wrote in post#8
- all pulses should have equal lenght.
Use oscilloscope for checking pulses.
