phatcreators
Full Member level 5
How the splice & cutter works in a web printing machine ? In order to split or cut the web during the printing process so that the printed web could wind on a bare core or on a new core .....
there's splice arm, nip infeed & cutter (cutting blade) ......
there are solenoid valves , cylinders ........
the output is generated by PLC which is the input (actuation) of the solenoid valve .....
the problem is that the cutter is not actuating & hence no cutting is happening ....
would the outputs are generated 1 by 1 in a sequence by the PLC like first the splice arm would come over (meet to the web winding roll) by sensing the film with the help of sensor and then nip actuates & then the cutter ???? Or all of the three outputs would be generated by PLC at once ????
thank$$
thank$$
