cadence spectre error (VACOMP-1008)
tompham
Full Member level 2
Full Member level 2
usa
Hi all
I am running cadence spectre veriloga simulation using ic610 and mmsim10.1. The output shows
ERROR (VACOMP-1008): cannot compile ahdlcmi module library spectre. My OS is ubuntu 11.10.
Anyone can help me to solve this problem? Thanks alot
Best Regards
Tom
I am not sure about the error you get. I got a similar error when using in windows. Later I found that there should be no space in file name or project name in cadence.
Try simulation again with file name or project name without space. Just give it a try and let me know.
Thank for reply me radnusmar
I am trying to follow this link and do exercise **broken link removed**
I follow every step and get problem
Hi ,
Has the Above mentioned link solved your problem or if by any other way if you had got a solution , Please can you share that .... Any suggestion is welcome.
Thanks ,
Yugandhar
Hi Tompham ,
Your solution worked like charm and yeah apart from that the shell also has to be changed to bash if in case your default shell is something else.
Hi yugan
Do you have problem with cadence ade XL? (run corners , monte carlo) ? I have problem with it and can not figure out how to deal
Hi yugan
ADE XL running vnc server which start to looking fonts at following path:
/usr/X11R6/lib/X11/fonts
which is deprecated in the most linux distributions.
Check if You have fonts in mentioned path and if not make simlink from /usr/share/fonts/X11/fonts.
Hi Dominik
Thanks for your suggestion. I did follow your direction and it runs but shows the error:
Error found by spectre during info `dcOpInfo'.
ERROR (SPECTRE-7011): Output for analysis of type `info' is not supported in WSF.
Error found by spectre during info `modelParameter'.
Error found by spectre during info `element'.
Error found by spectre during info `outputParameter'.
Error found by spectre during info `designParamVals'.
ERROR (SPECTRE-7011): Output for analysis of type `info.params' is not supported in WSF.
Error found by spectre during info `primitives'.
ERROR (SPECTRE-7011): Output for analysis of type `info.primitives' is not supported in WSF.
Error found by spectre during info `subckts'.
Do you have any idea to deal with it? Thanks a lot
hi Dominik,
I tried your suggestion as below but I still can't run ADE XL. Could you eleborate the detail - command, and exact directory name.
I'm using RHEL6.5.
Maybe suggest other solution?
1. I created a folder
/usr/X11R6/lib/X11
2. create a symbol link.
ln -s /usr/share/X11/fonts
3. verified the link by
ls
lrwxrwxrwx. 1 root root 20 May 15 13:47 fonts -> /usr/share/X11/fonts
4. try with
virtuoso -nograph
*WARNING* Could not open display hostname:80. If no X server is running for this display,
*WARNING* remove the file /tmp/.X80-lock: owner me, last modified Thu May 15 09:36:46 2014
no luck.
thanks.
