[SOLVED] how to detect rising edge on 8051
ud23
Advanced Member level 3
hi all i want to detect proxy output any pin of 8051 but i want to detect on rising edge only. i know with external interrupts its possible only falling edge
Do you need interrupt or not?
IF not then i think it is very simple.
when your pin goes from "0" to "1" it is your rising edge.
regards
no i don't need interrupts. as you said it is rising edge but how to detect in c i know "0" to "1" also consider as state change for that pin i need to take action only while perticular pin goes from"0" to towards "1" not when its become after complete "1".
What i understand that u want to take action in time between a particulate pin start changing its state from "0" to "1".
If yes then i think that is not possible using a digital input. You can use an analog input for this purpose. When ADC goes from low value to high value you can take action.
Regards
you make that pin in a while loop.. i mean
for eg,
sbit input=P2^0;
main()
   while(input==0);//wait till rising edge
  // next action
Code C - [expand]
8
9
10
sbit input=P2^0;
bit flag;
main()
if(!input)
flag=1;
if(flag&&input)
{//this is for rising edge
//do action on rising edge
flag=0;
---------- Post added at 10:55 ---------- Previous post was at 10:27 ----------
try this
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
#include<reg51.h>
sbit in=P2^0; //input for rising edge
sbit led=P2^1;//led toggle on rising edge
bit flag; //for lavel chang on input pin
void main()
led=0;
in=1;//for input
while(1)
if(!in)
flag=1; //flage set on input pin is low
if(flag&&in)//for pin state change low to high
led^=1;
flag=0;//flag reset while pin is high
