Is 220V & 110 V are digital signals (digital supplies) ?
munzir
Full Member level 6
Full Member level 6
Pak
If a plc is giving output in terms of 220V or 110 V then can we call these digital outputs ?
PLC will output dry contacts (relay output) or 5 / 24 VDC (depending on the PLC)
I think the output may be called as digital output if the output is either 110V/220V (for on) and 0V (for off). I think you can call this digital control because there are 2 states of the output (1 - 110V/220V and 0 - off). But the 220VAC sine wave itself is not digital since the values vary continuously according to the sine wave.
Hope this helps.
Tahmid.
Hi All
I'm agree with Tahmid , just the square waves what have on or off , or things alike them , called digital signals .
Regards
Goldsmith
A digital signal is a physical signal that is a representation of a sequence of discrete values (a quantified discrete-time signal),
for example of an arbitrary bit stream, or of a digitized (sampled and analog-to-digital converted) analog signal.
The term digital signal can refer to
-a continuous-time waveform signal used in any form of digital communication.
-a pulse train signal that switches between a discrete number of voltage levels or levels of light intensity,
also known as a a line coded signal, for example a signal found in digital electronics or in serial communications
using digital baseband transmission, or a pulse code modulation (PCM) representation of a digitized analog signal.
A signal that is generated by means of a digital modulation method (digital passband transmission), produced by a modem,
is in the first case considered as a digital signal, and in the second case as converted to an analog signal.
https://en.wikipedia.org/wiki/Digital_signal
Hi All
Regards
Goldsmith
Yes. After all, the digital output from a microcontroller or digital chip is usually square wave (VCC/VDD for high, GND for low).
so, can we call them (110V or 220V) output voltage of a PLC to digital output OR not ?
If considering a wave (i.e sine wave or cosine wave) then its a analogue voltage (supply) ? Right ???
Dear danishdeshmuk
Hi
Yes you're quite right .
Best Wishes
Goldsmith
---------- Post added at 22:11 ---------- Previous post was at 22:09 ----------
But the out put of a PLC isn't digital , because it's relay , will conduce a sine wave .
but the command of it's out put relay , is digital.
I would say no, they are not digital signals.
These outputs supply only on/off-control power to relays, actuators , etc...
They dont carry any coded information.
If for example : four of these outputs generate four bit parallel binary code , then these four outputs are giving digital signals
If for example : one output is giving morse code , then this output is giving time coded digital signal.
