[SOLVED] features of GLCD JHD12864E.....?
saur
Member level 2
Member level 2
I'm having a confusion as to whether KS0107 and KS0108 are in-built within JHD12864E or not.....
Pls help me anyone as soon as possible.....
Thanks....
Thanks....
Just look at the datasheet for the display, its very clear they are onboard.
Thanks wp100....but can u also send me a link to its datasheet....
And also if possible someguide lines as to how to use the datasheet.....i usually get confused reading it and mis-interpret some things...
Thanks again...
---------- Post added at 06:25 ---------- Previous post was at 06:19 ----------
Sir,
Do u mean to say JHD12864E need external driver chips or are they on board the Glcd?
And i'm trying to interface it with 8051 micro-controller....
So do u have any suggestions about it?.....
No, the display driver chipset to which I refer is incorporated into the GLCD.
JHD12864E Datasheet
The above datasheet indicates the GLCD utilizes a S6B0108 chipset which is in fact compatible with the KS0108 as I previously mentioned.
You'll need to register to download the source code from the above site.
Interfacing AT89S52 with GLCD
The above link features a development board with a KS0108 compatible GLCD, documentation, schematics and source code are available for download.
BigDog
Reactions: saur
    saur
Thanks a lot "bigdogguru" sir......
Ur last post was extremely useful.....
Thank u very much.....:)
