Switch Mode transformer winding Formulas Required!
billu8660
Junior Member level 1
Karachi
I need primary and secondary winding formulas for the following transformers,
(1) ETD 29,34,44,49.
(2)EE small/big.
(3)RM 10,12_small big.
(4)EC40.
(5)PQ3535.
Your question is too generic.
Check if this helps :
winding formulas are required not pwr supp topologies.
like for etd49
npri={(vin min/2)x10^8}/ 4 x f x b x ac
and
nsec={1.1(vout+vfd)xnpri}/vin min x dmax
similarly formulas or techniques are required to find primary/sec winding for all mentioned ones . :roll:
There is no single formula. The turns number will change based on topology. Eg. the transformer design for a flyback converter will be dictated by the primary inductance. This along with other factors such as air gap will determine the number of turns.
The turns ratio and turn numbers will vary for forward, push pull, half bridge, full bridge and other topologies.
Hope this helps.
Tahmid.
Hope this helps.
Tahmid.
Tahmid yaar thats what i am asking about tell me the source any web site books etc .....need methods for calculation....
The link posted above pretty much covers everything, categorized by topology.
But if you want a book, I would recommend Power Supply Cookbook - Marty Brown or Switching Power Supply Design - Abraham I Pressmen.
You can get a complete list of some such useful books here:
List of some useful books for SMPS
Hope this helps.
Tahmid.
the link posted above pretty much covers everything, categorized by topology.
But if you want a book, i would recommend power supply cookbook - marty brown or switching power supply design - abraham i pressmen.
list of some useful books for smps
hope this helps.
Tahmid.
thanks man
Practical Switching Power Supply Design - Marty Brown
Power Sources and Supplies - Marty Brown editor
High Frequency Switching Power Supplies-Theory and Design – George Chryssis
Demystifying Switching Power Supplies - Raymond A. Mack,Jr
Practical Design of Power Supplies - Ron Lenk
Regulated Power Supplies - Irving M. Gottleb
Switch mode Power Converters Design & Analysis - Keng C Wu
Switch mode Power Supply Handbook - Keith H. Billings
Switching Power Supplies A to Z - Sanjaya Maniktala
FREE DOWNLOAD LINKS PLEASE 😁
for transformer design, theory design is only starting step, it mains if the transformer can be made, so we need adjust and optmize preliminary design when wemake samples by ourself, practice is more importance,e.g how to reduce leakage inductance and capacitance, how to ensure creepage and clearance distance, and how adjust winding position and reduce or rise output voltage, how to pass THD and very high surge voltage,how reduce power loss, how to reduce noise,how to cost down, and so on, so it is not simply work.
