24 vdc to 600 vdc circuit
ahgu
Full Member level 3
Full Member level 3
anyone has a circuit to convert 24vdc to 600vdc .
output current 300mA.
cannot use transformer.
Would these off-the-shelf switch handle such voltage with high voltage diode and switches?
What do I have to watch out? Can I just use the same switching boost topology for such high voltage?
thanks
ahgu
What do you think about flyback converter (like those used in TV) ?
as long as it can supply 600vdc, 80mA
do you have a working circuit ?
thanks
Andrew
