omar-malek
Member level 5
- Joined
- Mar 24, 2007
- Messages
- 89
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- French
- Activity points
- 1,949
hi to all .
Can any one explain me this ligne in the code of counter
cnt <= conv_std_logic_vector(CONV_INTEGER(cnt) + 1, width);
thank you.
ibrary IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_ARITH.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
entity COUNTERCLR is
generic (
width : integer := 8);
port (
clk : in std_logic;
rst_n : in std_logic;
en : in std_logic;
clear : in std_logic;
outcnt : out std_logic_vector(width-1 downto 0));
end COUNTERCLR;
architecture COUNTERCLR1 of COUNTERCLR is
signal cnt : std_logic_vector(width-1 downto 0);
begin -- COUNTERCLR1
process (clk, rst_n)
begin -- process
if rst_n = '0' then -- asynchronous reset (active low)
cnt <= (others => '0');
elsif clk'event and clk = '1' then -- rising clock edge
if en = '1' then
cnt <= conv_std_logic_vector(CONV_INTEGER(cnt) + 1, width);---- CONV_STD_LOGIC_VECTOR(integer, bits)
elsif clear = '1' then
end if;
end if;
end process;
outcnt <= cnt;
end COUNTERCLR1;
thank you.
ibrary IEEE;
generic (
port (
clk : in std_logic;
en : in std_logic;
end COUNTERCLR;
begin -- process
if en = '1' then
end if;
end if;
end process;
outcnt <= cnt;
end COUNTERCLR1;
