regarding non default rule
venkatramanan
Member level 4
Member level 4
bangalore
what is the main purpose of using non default rule?already we having rules in tech lib?then y we are using that rule is clock specification file?
thank u :) another one doubt ...what is the differnce between clk buffer and normal buffer?
i know that clk buffer having equal rise time and fall time.and normal buffer not like that.but they asking what is schematic diagram for both what is funtional operation for both?
The Clock buffers would be bigger than the normal buffers in size.
U need equal rise and fall times for clock so that u have same amount of duty cycle.
Hope it helped....
Schematic will be same except for extra LVT or HVT layers. Functional operation ish. also the same except that clock buffers are used in clock paths and normal ones in data pat
