SIGI44
Junior Member level 1
I would like to buy a RF signal generator in the range 3 to 4 Ghz.
Unfortunatly I have not the money to buy it now. (we've a lot more taxes to pay now in Italy !)
A the moment my need is to have a signal generator offering a level at least an average of -10 dBm (don't care the flatness of the signal level)
I have a specrum analyzer ReS and using the Tracker at 0 span I get a signal generator in the range 100Khz-3Ghz (signal level out is 0 dBm)
I have also a good RF generator in the range 100 Khz-1.2 Ghz (max level out 7 dBm)
Anyone can tell me if using a mixer (wich mixer ?) and mixing the two signals can I obtain a signal from 3 to 4 Ghz (at least - 10 dBm)
If yes, thank you in advance for the info about the mixer I have to use.
Giovanni Siccardi
Giovanni Siccardi
