How to set acceleration time low & hight in Mitsubishi Freqrol A500 inverter ?
dineshdeshmuk
Full Member level 5
Full Member level 5
How to set acceleration time low & hight in Mitsubishi Freqrol A500 inverter ? (Acceleration Parameter)
How to go into the menu ?
thanks
Re: How to set acceleration time low & hight in Mitsubishi Freqrol A500 inverter ?
Download this
TRANSISTORIZED INVERTER
MITSUBISHI FR A-500
INSTRUCTION MANUAL
https://www.mrostop.com/pdfs/A500_manual.pdf
Look 3.2 Operation Panel ............. page 53
4.1 Parameter Lists .....................page 64
4.2.5 Acceleration/deceleration time ......................page 77
(Pr. 7, Pr. 8, Pr. 20, Pr. 21, Pr. 44, Pr. 45, Pr. 110, Pr. 111)
Download this
MITSUBISHI FR A-500
INSTRUCTION MANUAL
thanks though
What does it mean by "7.5K or less & 11K or more " in the Parameter number column in page 77 ?
Please notice the inverter type designation, referring to output powers.
Some factory setting values of the parameters depends on the inverter capacity.
If noted on "The setting depends on the inverter capacity" ,
check inverter capacity from rating plate or capacity plate.
eg.
7.5K or less parameter value is xxxx
11K or more parameter value is xxxx
