lsuphysmn
- Joined
- Jan 19, 2012
- Messages
- 7
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Baton Rouge, LA
- Activity points
- 1,349
I would like to power on and off a high voltage (HV) power supply using up and down ramp generators. The HV power supply can be controlled with a 0-10Vdc input that linearly provides 0 to max output. Here is the idea:
When turning "ON" the HV power supply, a slow 0-10V ramp will produce a corresponding 0 - max HV output.
When turning "OFF" the HV power supply, the 10V input will be slowly ramped back down to 0, thus the HV output will correspondingly ramp back down to zero.
Off hand I am thinking a simple op-amp integrator circuit that charges/discharges a capacitor might provide a linear voltage ramp. Ideally this will be a simple push-button (on/off toggle) operation. Ramp rates (0-10V input) would be on the order of 1V/min. I would be interested in any other suggestions.
