madebyagra
Junior Member level 3
I have make a planar toothed log periodic antenna with broadband characteristic, but in the gain measurement ( i used two antenna method) and use the formula (in balanis antenna book), unfortunately i found the gain value (in dB) is negative, what the meaning of negative value? is it an attenuation? or a loss?
thanks b4
thanks b4
