Adajo
Junior Member level 1
pls I need an explanation on the run time of a battery. for example with 500W load, how lond will it take a 12v 7ah battry to discharge. not that the battery is used to power inverter of output 220volts.
7Ah implies that the battery can draw current of 7 Ampere for 1 hour...
so, for a 500W of load,
Watt=Volt*Ampere
Which implies, A=W/V => A=500/12 => A=41.66
That is for power consumption of 500W, the battery will draw a current of 41.66 A...
To calculate the time it can withstand:
Since 7A lasts for 1 hr,
then 41.66A will last for x hr
therefor x= (7/41.66)*60....... | 1hr = 60 minutes
=> 0.16 hr or approximately 10 mins...
Since there is an obvious power loss by the inverter and also some other effect, the time shortens to 7-8 mins...
May be my concept is wrong... But I learnt this fact in some websites...
Any way, thanx for the correction...
