KX36
Junior Member level 2
- Joined
- Jul 16, 2011
- Messages
- 23
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,283
- Activity points
- 1,579
Hi all,
I've been reading up on switched mode power supplies just as general interest, and this is the first time I've looked at a circuit with any significant electronics on the primary side of the transformer, connected to mains. I have seen in many circuit block diagrams that the ground connections on either side of the transformer have different symbols. Here's an example circuit diagram I quickly found to show what I'm talking about incase it's not clear, note the ground symbols on either side of the transformer.
I would assume this means the grounds can't be connected together in order to maintain the galvanic isolation of the secondary side from the mains for safety; so what do you normally do with these two grounds when they both need to be grounded but can't be connected?
My guess would be that it involves a capacitor, like in the olden days when some countries used 2-prong power cords without a protective earth connection and "ground" was just a series capacitor from neutral. If it is a capacitor connecting the two grounds, is this one of those situations where it legally has to be a class X/Y capacitor etc, and which side would be connected to the protective earth?
Cheers,
Matt
Cheers,
Matt
