Magnetics for Ethernet, RJ45?
digi001
Full Member level 5
Full Member level 5
Do most RJ45 connectors contain integrated magnetics?
Is it ok if Ethernet goes through 2 sets of RJ45 connectors with magnetics before it leaves a system?
For example, the ethernet starts on a CPU board then travels to a connector board via CAT5. Then goes off this 2nd board via another RJ45 with magnetics.
Any problem doing this?
Today most have magnetics, but there is also RJ45 without this.
SFE Footprint Library Eagle
  • B78477P1_A_14.pdf
  • MagneticlessEth.pdf
  • RJ47-xxxx.pdf
Reactions: digi001
    digi001
LINK-PP is a specialized manufacturer of Lan Transformer and RJ45 with magnetic certificated by ISO9001:2000 and UL .
