cadusir
Newbie level 5
Hi
First of all I'm a newbie in electronics so please don't get angry with my primitive questions.
Concept:
I want to use LED's as back-light for a LCD monitor.
(Powers is perfect but inverter is gone and parts are not available. they want 65$ for a "used" "repaired" inverter so I decided to do this)
I read a lot about back lighting and other things. finally found a probably good circuit diagram for my purpose in a Russian site (used Google translate).
here it is:
the circuit seem perfect for me but I have to do some modifications:
1. I have to use 60 LED's
2. I want to have the option of dimming the LED's (not logical, a simple potentiometer would be OK).
Now what I want to know:
1. Is it better to make two units for every 30 LED's?
2. this circuit has 41 LED's but I want to use 30 or 60, what should I do? 3 rows of 10 LED's? 4 rows of 15 LED's? or else?
3. I found a website (**broken link removed**) that calculates all the values and give the parts, but I'm confused because:
a) It wont give standard values for the parts. (the most important of them for me is L1)
b) I don't know how to configure the LED's so I can't calculate needed voltage and other parameters.
what I have:
1. 14V power source.
2. 60 LED's (SMD-3528) VF 3.2v, If 20mA, Pd 173mW.
3. 5 volts on/off signal to feed the FET for turning on/off the circuit.
OK, I know it's kind of rudeness but the final request would be:
1. LED configuration.
2. part values.
Any suggestions would be appreciated even referring me to further reading would be OK.
Thank you
Concept:
here it is:
what I have:
2. part values.
Thank you
