Adjustable/Resetable Digital Alarm Clock using 8051(89s52/89c52) in 7 segment display
adambose1990
Kolkata, India
This is a whole new Digital alarm clock in 7-segment display....... Some user interface facility is given here.
This is the circuit diagram....
Components used:
4 7-segment displays
1 AT89s52/AT89c52
28 Resistors of 150 ohm
1 Capacitor 10uF
2 Capacitors 33pF
5 volt Buzzer
1 12MHz crystal
5 Red LEDs
4 DIP switches (push button)
Description:
2 switches 'HOUR' and 'MINUTE' have been used for increasing the hour and minute in display. The clock will show 12:00 AM while switching for the first time. Then adjust the time using those HOUR and MINUTE buttons. If you want to set alarm push SET ALARM button then adjust the hour and minute and then push SAVE ALARM button. When the alarm buzzer is ringing press SET ALARM twice to stop the buzzer. This will ensure your awaking. There are two LEDs for indication AM and PM respectively. Another 2 LEDs are used for second-clock-indication. The lower LED will blink for the first 30 secs and upper one will blink for the rest 30 secs. When you are have set an alarm timing, another LED will glow.
So this is pretty cool na? I think this is much user friendly.
Coding: Coding is done in BASCOM 8051 V2.0.11.0. Its very easy, you can convert it to its equivalent C program after you understand the code.
' Description:
' Compiled by BASCOM 8051 Demo
' [url=https://www.mcselec.com]Home - MCS Electronics[/url]
$regfile = "REG51.DAT"
' 7 Segment Pattern Data
Const Segpat0 = &B11000000                                    ' 0   ****A***
Const Segpat1 = &B11111001                                    ' 1   *      *
Const Segpat2 = &B10100100                                    ' 2   F      B
Const Segpat3 = &B10110000                                    ' 3   *      *
Const Segpat4 = &B10011001                                    ' 4   ****G***
Const Segpat5 = &B10010010                                    ' 5   *      *
Const Segpat6 = &B10000010                                    ' 6   E      C
Const Segpat7 = &B11011000                                    ' 7   *      *
Const Segpat8 = &B10000000                                    ' 8   ****D***
Const Segpat9 = &B10011000                                    ' 9
Const Segpblk = &B11111111                                    ' 10 BLANK
Hour10 Alias P1.0
Led_am Alias P1.1
Led_pm Alias P1.2
Piezo Alias P1.3
Sw_alarm Alias P1.4
Sw_exit Alias P1.5
Sw_hour Alias P1.6
Sw_min Alias P1.7
Dim Icount As Word
Dim Clock_cent As Byte
Dim Clock_second As Byte
Dim Clock_min As Byte
Dim Clock_hour As Byte
Dim Alarm_min As Byte
Dim Alarm_hour As Byte
Dim Data_min As Byte
Dim Data_hour As Byte
Dim Tempa As Byte
Dim Tempb As Byte
Dim Tempc As Byte
Dim Beep As Bit
Dim Dot_high As Bit
Dim Dot_low As Bit
Dim Dot_alarm As Bit
On Timer0 Timebase                                            ' Timer0 Interrupt
Config Timer0 = Timer , Gate = Internal , Mode = 2            ' Timer0 Auto Reload Timer Mode
Load Timer0 , 200                                             ' Auto Reload Constant 200 uSec
Start Timer0                                                  ' Start Timer0
Enable Timer0                                                 ' Enable Timer0
Enable Interrupts                                             ' Enable All Interrupt
Icount = 0
Clock_cent = 0
Clock_second = 0
Clock_min = 0
Clock_hour = 0
Alarm_min = 0
Alarm_hour = 0
Beep = 0
Dot_alarm = 1
Main_clock:
If Clock_cent > 99 Then
   Clock_cent = 0
   Incr Clock_second
End If
If Clock_second > 59 Then
   Clock_second = 0
   Incr Clock_min
End If
If Clock_min > 59 Then
  Clock_min = 0
  Incr Clock_hour
End If
If Clock_hour > 23 Then
  Clock_hour = 0
End If
Data_min = Clock_min : Data_hour = Clock_hour
Gosub Dot_proc
Gosub Clock_disp
If Sw_alarm = 0 Then
   Gosub Alarm_proc
End If
If Sw_min = 0 Then
   Clock_second = 0
   Incr Clock_min
      Clock_min = 0
   End If
   Waitms 100
End If
If Sw_hour = 0 Then
   Incr Clock_hour
      Clock_hour = 0
   End If
   Waitms 100
End If
If Dot_alarm = 0 Then
   If Clock_hour = Alarm_hour Then
      If Clock_min = Alarm_min Then
         Set Beep
      Else
         Reset Beep
      End If
   Else
      Reset Beep
   End If
Else
   Reset Beep
End If
Goto Main_clock
Clock_disp:
Tempa = Data_min Mod 10 : Gosub Patconv
  Tempb = Tempb And &H7F
End If
P3 = Tempb
Tempa = Data_min / 10 : Gosub Patconv
If Dot_high = 0 Then
End If
P2 = Tempb
If Data_hour < 12 Then
   Reset Led_am : Set Led_pm
   Tempc = Data_hour
 Else
   Reset Led_pm : Set Led_am
   Tempc = Data_hour - 12
End If
If Tempc = 0 Then
  Tempc = 12
End If
Tempa = Tempc Mod 10 : Gosub Patconv
If Dot_low = 0 Then
End If
P0 = Tempb
Tempa = Tempc / 10
If Tempa = 1 Then
   Reset Hour10
   Else
   Set Hour10
End If
Return
Dot_proc:
If Clock_second < 30 Then
   Reset Dot_low
   If Clock_cent < 50 Then
       Reset Dot_high
   Else
       Set Dot_high
   End If
Else
   Reset Dot_high
       Reset Dot_low
   Else
       Set Dot_low
   End If
End If
Return
Alarm_proc:
Set Dot_high : Set Dot_low
Data_min = Alarm_min : Data_hour = Alarm_hour
Gosub Clock_disp
Waitms 100
Alarm_loop:
Gosub Clock_disp
If Sw_min = 0 Then
   Incr Alarm_min
   If Alarm_min > 59 Then
      Alarm_min = 0
   End If
   Waitms 100
End If
If Sw_hour = 0 Then
   Incr Alarm_hour
   If Alarm_hour > 23 Then
      Alarm_hour = 0
   End If
   Waitms 100
End If
   Set Dot_alarm
   Goto Alarm_ret
End If
If Sw_exit = 0 Then
   Reset Dot_alarm
   Goto Alarm_ret
End If
Goto Alarm_loop
Alarm_ret:
Waitms 100
Return
Patconv:
Tempa = Tempa And &H0F
Select Case Tempa
  Case 0 : Tempb = Segpat0
  Case 1 : Tempb = Segpat1
  Case 2 : Tempb = Segpat2
  Case 3 : Tempb = Segpat3
  Case 4 : Tempb = Segpat4
  Case 5 : Tempb = Segpat5
  Case 6 : Tempb = Segpat6
  Case 7 : Tempb = Segpat7
  Case 8 : Tempb = Segpat8
  Case 9 : Tempb = Segpat9
  Case Else
End Select
Return
Timebase:
Incr Icount
If Icount > 49 Then                                           ' 49
   Icount = 0
   Incr Clock_cent
End If
If Beep = 1 Then
   If Piezo = 1 Then
     Reset Piezo
   Else
     Set Piezo
   End If
End If
If Beep = 0 Then
   Set Piezo
End If
Return
'============================ END OF FILE ==================================
or do something funny, just make a .hex file using you notepad and copy these following codes into it.
:1000000002006632000000000000000203700000E1
:10001000000000320000000000000032000000007C
:10002000000000320000000000000000000012008C
:100030003A60044002E422740122C3EDB50706ECE5
:10004000B50602E422740122F874AD040000000039
:100050000000000070F500D8F022E62401F6FA084E
:10006000E63400F64A22787FE4F6D8FD75813075D3
:100070002000C28CE58954F02402F589758A387510
:100080008C38D28CD2A9D2AF75220075230075248A
:100090000075250075260075270075280075290054
:1000A000C205D208E524B46302800250030200B501
:1000B0007524000525E525B43B02800250030200AB
:1000C000C67525000526E526B43B028002500302D2
:1000D00000D77526000527E527B4170280025003D4
:1000E0000200E675270085262A85272B511A316BD9
:1000F000A294920450030200FB5154A29792045020
:100100000302011C7525000526E526B43B0280028A
:10011000500302011875260074641148A2969204D7
:10012000500302013A0527E527B417028002500365
:1001300002013675270074641148A2089204500326
:10014000020166E527B529028003020161E526B5B3
:100150002802800302015CD20502015EC205020191
:1001600063C205020168C2050200A475F00AE52A0F
:1001700084C0F0782CD0E0F651CCA2089204500351
:10018000020186532D7F852DB075F00AE52A84C0C3
:10019000E0782CD0E0F651CCA20692045003020184
:1001A000A4532D7F852DA0E52BB40C0280024003C3
:1001B0000201BDC291D292852B2E0201D0C292D2F1
:1001C0009175F00CE52BC395F0C0E0782ED0E0F6E9
:1001D000E52EB4000280030201DD752E0C75F00AD5
:1001E000E52E84C0F0782CD0E0F651CCA207920422
:1001F00050030201F8532D7F852D8075F00AE52EFE
:1002000084C0E0782CD0E0F6E52CB4010280030233
:100210000217C290020219D29022E525B41E028074
:1002200002400302023EC207E524B43202800240CB
:1002300003020239C20602023BD206020253C20680
:10024000E524B4320280024003020251C2070202D6
:1002500053D20722D206D20785282A85292B316B53
:100260007464114885282A85292B316BA297920442
:10027000500302028A0528E528B43B02800250039D
:1002800002028675280074641148A29692045003F5
:100290000202A80529E529B41702800250030202D0
:1002A000A475290074641148A294920450030202B8
:1002B000B6D2080202C7A295920450030202C4C239
:1002C000080202C70202647464114822532C0FE52D
:1002D0002CB4000280030202DF752DC002036FE51B
:1002E0002CB4010280030202EF752DF902036FE5C1
:1002F0002CB4020280030202FF752DA402036FE5F5
:100300002CB40302800302030F752DB002036FE5C6
:100310002CB40402800302031F752D9902036FE5BC
:100320002CB40502800302032F752D9202036FE5A2
:100330002CB40602800302033F752D8202036FE591
:100340002CB40702800302034F752DD802036FE51A
:100350002CB40802800302035F752D8002036FE551
:100360002CB40902800302036F752D9802036F22DB
:10037000C0D0C2D3C0E0C0F0C083C082C000C00102
:10038000C002C003C004C005C006C007C008C00941
:10039000C00AC00BC00CC00DC00EC00FC010C011F1
:1003A0007822115AAC22AD237E317F00112E6003DA
:1003B0000203BB7522007523000524A205920440A8
:1003C000030203D4A293920440030203D2C2930215
:1003D00003D4D293A205920450030203DFD293D038
:1003E00011D010D00FD00ED00DD00CD00BD00AD021
:1003F00009D008D007D006D005D004D003D002D051
:1004000001D000D082D083D0F0D0E0D0D032000034
:00000001FF
You also can download following rar file containing everything you need.
.bas //for Bascom
.hex
.jpg
.dsn
  • Desktop.rar
did you write your code by yourself ? where is rtc chip?
---------- Post added at 01:42 ---------- Previous post was at 01:38 ----------
as you said this is easy its easy to copy or easy to write code i could not understand ?
@harishwww you dont need to incorporate the RTC IC here, because the delay loop inside the main clock is adjusted for 1 sec by itself for 12MHz crystal.
and I said If you dont have any compiler, just copy the hex code written above and paste in a .hex file(which can be made easily by notepad) and burn it on th MCU chip. so its easy. And if you go for writing the code by yourself, you are always welcome.
Adam..Thanks for the nice project. In fact i had built a similar project from josepino.com which used PIC16F628 with 4.000 mhz crystal with high accuracy. Using 4.0 Mhz will affect the accuracy of the clock. The accuracy of the later was better than Ds1307+crystal kits where all depends on the cylindrical crystal. I was wondering wether you have checked this project about how is the accuracy.
Cheers
@pranam Yes you are right, there's nothing about accuracy here, but i have checked the main delay loop, and set that for 1 sec delay. I didnt used RTC IC only to reduce the cost and size and complicity as well. One can surely use those stuffs. This is a simple project for a beginner I thought.
Thanks.
