Liamlambchop
Member level 2
Hello all,
I have a Vishay TSOP34138 IR receiver module. It's carrier frequency is 38Khz. I have it connected to 5Vs and am getting a current flow (from the Vs to the ground) through the device when there is no IR present. This is a problem.
The diagram, labelled 'block diagram', on the first page of the module's data sheet (https://www.newark.com/pdfs/datasheets/vishay/TSOP34.pdf), shows that when the base of the transistor in the receiver module isn't activated there should be no current flow. Considering that I'm getting current flow I am assuming that my base is activated. But it shouldn't be, because my IR receiver module should only respond to 38KHz radiation.... and I'm not producing any of that.
I don't understand how this is happening........
I have this receiver module so I can use it as a sensor for an IR LED (data sheet: https://www.farnell.com/datasheets/391119.pdf) in a break beam counter. I am using an Arduino to make the IR LED blink at 38KHz . (NOTE: the problem described above still occurs when my IR LED is not plugged in.
Also, what sort of output will my receiver module have? I know that the info is in the data sheet, but I am not familiar with all of the jargon yet. What i'd like to know is: What is the max output voltage of the receiver, and is this large enough for a data logger to recognise it as a digital high?
Any help would be greatly appreciated
Thank you,
Liam
Thank you,
Liam
