Felipebrz
I'm just starting on the 18F family (using the 18F2550) and with the C18 compiler.
I created a circuit with two LEDs and the LCD. First I did a simple blinking leds example with it, which worked perfectly. I'm using the internal oscilator, configured to 8MHz.
The LCD only has written 1602F REV:I behind it, so I assume thats the LCD's controller. I've counted the dot matrix for each character and it looks like it is a 5x8 (even though it doesnt mention this kind in the xlcd library)
I am using MPLAB v8.73 and C18 v3.40. And using a PICkit2 to program my PIC.
Seeing examples around the net, I have connected the LCD pins D4-D7 to RB0-RB3, while RS=RA0, RW=RA1 and E=RA2.
The main .c file is:
Below are the modified parts of the xlcd.h file:
on the project tree I have:
Source files:
- LCD.c
Header files:
- delays.h (in the same folder as LCD.c)
- p18f2550.h
- string.h (in the same folder as LCD.c)
- xlcd.h (in the same folder as LCD.c)
Linker script:
- 18f2550_g.lkr
And after all that, my LCD shows nothing!
I tried adjusting the brightness (using a 10k pot) but thats not the problem.
Can anyone help me with this? Any other information that may help, just say so.
Thanks!
// Arquivos de cabeçalho
#include <p18f2550.h> // Processador = 18F2550
#include <delays.h> // Funções de delay do compilador C18:
#include <string.h>
#include "xlcd.h" // Funções do display LCD 2x16
// 1 TCY = 4/FOSC ==> @ 8 MHz ==> 1 TCY = 0,5 us
// Delay1TCY() = 0,5 us
// Delay10TCYx() = 5 us
// Delay100TCYx() = 50 us
// Delay1KTCYx() = 500 us = 0,5 ms
// Delay10KTCYx() = 5000 us = 5 ms
// Configurações do processador
#pragma config PLLDIV = 1
#pragma config CPUDIV = OSC1_PLL2
#pragma config FOSC = INTOSCIO_EC // Oscilador interno
#pragma config FCMEN = OFF
#pragma config IESO = OFF // Troca de oscilador desabilitada
#pragma config PWRT = OFF // Habilita o Power-up Timer (PWRT)
#pragma config BOR = OFF // Brown-out Reset (BOR) habilitado somente no hardware
#pragma config VREGEN = ON // Regulador de tensão da USB habilitado
#pragma config WDT = OFF // Desabilita o Watchdog Timer (WDT)
#pragma config MCLRE = OFF // MCLR desabilitado; RE3 = Input
#pragma config PBADEN = OFF // RB0,1,2,3 e 4 configurado como I/O digital.
#pragma config LVP = OFF // Desabilita o Low Voltage Program
#pragma config XINST = OFF // Conjunto de instruções extendido desabilitado
#pragma config DEBUG = OFF // Debugger desabilitado
#pragma config CP0 = OFF // Proteção do bloco 0 desabilitada
#pragma config CP1 = OFF // Proteção do bloco 1 desabilitada
#pragma config CP2 = OFF // Proteção do bloco 2 desabilitada
#pragma config CP3 = OFF // Proteção do bloco 3 desabilitada
#pragma config CPB = OFF // Proteção do bloco de boot desabilitada
#pragma config CPD = OFF // Proteção do bloco da EEPROM desabilitada
#pragma config WRT0 = OFF // Proteção de escrita do bloco 0 desabilitada
#pragma config WRT1 = OFF // Proteção de escrita do bloco 1 desabilitada
#pragma config WRT2 = OFF // Proteção de escrita do bloco 2 desabilitada
#pragma config WRT3 = OFF // Proteção de escrita do bloco 3 desabilitada
#pragma config WRTB = OFF // Proteção de escrita do bloco de boot desabilitada
#pragma config WRTC = OFF // Proteção de escrita do bloco de config desabilitada
#pragma config WRTD = OFF // Proteção de escrita do bloco da EEPROM desabilitada
// Definições de variáveis de IO:
#define VERMr PORTCbits.RC0 // LED vermelho grande (pino 11): leitura
#define VERMw LATCbits.LATC0 // LED vermelho grande (pino 11): escrita
#define VERDr PORTAbits.RA4 // LED verde grande (pino 6): leitura
#define VERDw LATAbits.LATA4 // LED verde grande (pino 6): escrita
// Rotinas auxiliares
void DelayFor18TCY(void)
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
void DelayPORXLCD(void)
Delay1KTCYx(30); // Delay of 15ms
// Cycles = (TimeDelay * Fosc) / 4
// Cycles = (15ms * 8MHz) / 4
// Cycles = 30,000
return;
void DelayXLCD(void)
Delay1KTCYx(10); // Delay of 5ms
// Cycles = (5ms * 8MHz) / 4
// Cycles = 10,000
return;
unsigned char lcd[17];
// Início do programa
void main(void)
Delay10KTCYx(190);
// Definição das variáveis locais
// Configurações de módulos
OSCCONbits.IRCF2=1; // Configuração para clock de 8 MHz
OSCCONbits.IRCF1=1;
OSCCONbits.IRCF0=1;
OSCCONbits.SCS1=1; // Oscilador interno para sistema
ADCON0=0b00000000; // Módulo AD desligado (pag.265)
ADCON1=0b00001111; // Todas as portas são digitais (pag.266)
CMCON=0b00000111; // Desliga os comparadores (pag. 277 e 278)
// Configuração de direção das portas
TRISA=0b00000000;
TRISB=0b00000000;
TRISC=0b00000000;
LATA=0b00000000; //Coloca o PORTA em 0V.
LATB=0b00000000; //Coloca o PORTA em 0V.
LATC=0b00000000; //Coloca o PORTA em 0V.
// Configurando LCD
OpenXLCD(FOUR_BIT & LINES_5X7);
while(BusyXLCD());
WriteCmdXLCD(DON & BLINK_OFF & CURSOR_OFF);
while(BusyXLCD());
WriteCmdXLCD(0x01);//clear display
memset(lcd,'\0',17);
strcpypgm2ram(lcd,"hello world");
putsXLCD(lcd);
while(1)
#ifndef __XLCD_H
#define __XLCD_H
#include "p18f2550.h"
/* PIC18 XLCD peripheral routines.
* Notes:
* - These libraries routines are written to support the
* Hitachi HD44780 LCD controller.
* - The user must define the following items:
* - The LCD interface type (4- or 8-bits)
* - If 4-bit mode
* - whether using the upper or lower nibble
* - The data port
* - The tris register for data port
* - The control signal ports and pins
* - The control signal port tris and pins
* - The user must provide three delay routines:
* - DelayFor18TCY() provides a 18 Tcy delay
* - DelayPORXLCD() provides at least 15ms delay
* - DelayXLCD() provides at least 5ms delay
/* Interface type 8-bit or 4-bit
* For 8-bit operation uncomment the #define BIT8
/* #define BIT8 */
/* When in 4-bit interface define if the data is in the upper
* or lower nibble. For lower nibble, comment the #define UPPER
/* #define UPPER */
/* DATA_PORT defines the port to which the LCD data lines are connected */
#define DATA_PORT PORTB
#define TRIS_DATA_PORT TRISB
/* CTRL_PORT defines the port where the control lines are connected.
* These are just samples, change to match your application.
#define RW_PIN LATAbits.LATA1 /* PORT for RW */
#define TRIS_RW TRISAbits.TRISA1 /* TRIS for RW */
#define RS_PIN LATAbits.LATA0 /* PORT for RS */
#define TRIS_RS TRISAbits.TRISA0 /* TRIS for RS */
#define E_PIN LATAbits.LATA2 /* PORT for D */
#define TRIS_E TRISAbits.TRISA2 /* TRIS for E */
Source files:
- LCD.c
Header files:
- p18f2550.h
Linker script:
- 18f2550_g.lkr
Thanks!
