meandering technique for microstrip antenna on 2.4 GHz
Harys Zhendykiawan
Surabaya, Indonesia
Dear all,
My name Harys, and I'm beginner making antenna
I making antenna for my Year Assignment in my college.
And there's something that i wanna ask you
Will you explain about the Meandering technique in patch?
I can't found the basic explanation of it.
well, meandering is very new for me. And now i try to get some information about it read some article and try asking to the Expert.
antenna that I will make is the microstrip patch panels located at a frequency of 2.4 GHz with meandering method ..
but I do not understand about the parameters of meandering, meandering techniques and methods of meandering on the microstrip patch antenna panel at a frequency of 2.4 Ghz.
I Hope you want to spend your time helping me
Thank you for your attention :)
I'll be waiting for your Reply...
Best regards
Harys,
Meandering is a miniaturization technique.
The length of an antenna is related to its operating frequency. For example, the length of a patch antenna is half a wavelength. Meandering consist on folding the antenna several times to fit the same antenna length in an smaller volume.
The advantage is a smaller size, but the price you pay is a narrower bandwidth.
Means meandering is a technique to reduce the antenna with long winding curves that will be a smaller dimension.
but I am confused is how to create a meandering bend of an antenna with this technique with a frequency of 2.4 GHz, meaning how to form a wide bend, the length of a bend or curve shape. is there a calculation to determine the bend-bend of the meandering technique at a frequency of 2.4 Ghz ..
if there is a source of books or other literature are listed as well please.
Thank you
literature given thanks ..
but that there is a broadband antenna in a compact book by kin wong lu Part 2.4 and 3.4.4 meandering technique working at a frequency of 800 Mhz.
whether the methods used in this 800Mhz frekeuensi similar to the method of making the microstrip antenna with a frequency of 2.4 Ghz .. because I am still confused with this meandering method ..
Are there any books or literature that is truly special to learn the techniques meandering microstrip antenna?
hi i didn't see paper for this frequency but u can use this technique for every frequency
you seen more data about this kind of antenna for RFID appication in MICROSTRIP AND
PRINTED ANTENNAS NEW TRENDS, TECHNIQUES AND APPLICATIONS by Yahia M.M. Antar in chap 9
  • 05385292.pdf
  • 04396310.pdf
