vinodstanur
Advanced Member level 3
- Joined
- Oct 31, 2009
- Messages
- 751
- Helped
- 114
- Reputation
- 234
- Reaction score
- 114
- Trophy points
- 1,333
- Location
- Kerala (INDIA)
- Activity points
- 7,054
How to set the GIE in mspgcc ?
// 2010 Kenneth Finnegan
// http://kennethfinnegan.blogspot.com/
// Two color blink clock running on MSP430 controller
#include "msp430G2101.h"
#define BLINK_ON 3000
#define BLINK_OFF 1500
#define BLINK_SPACE 6000
volatile unsigned char time[4];
volatile unsigned char mode;
// FUNCTIONS
void displayNum (int c);
void displayTime(void);
void displayTwiddle(void);
void pause (int c);
void main(void) {
WDTCTL = WDTPW + WDTHOLD; // Stop Watchdog Timer
BCSCTL3 = (BCSCTL3 & ~(XCAP0 | XCAP1)) | XCAP_1; // 6pF xtal
BCSCTL2 = 0xF8; // MCLK:LFXT1CLK/8 SMCLK:LFXT1CLK
P1DIR = 0x41;
P1OUT = 0x0F; // pull up resistors
P1REN = 0x0E; // pull up resistors enable
P1IE = 0x08; // Setup P1.3 for interrupt
P1IES = 0x08; // High -> Low transistion
P1IFG &= ~0x08; // Clear int flag
CCTL0 = CCIE;
CCR0 = 0;
TACCR0 = 0x7FFF; // Period of 32767 + 1
TACTL = 0x0211; // Timer_A: SMCLK, UP MODE, TAIE
while(1) {
mode = 0;
[COLOR="#FF0000"]_BIS_SR(LPM1_bits + GIE);[/COLOR]
switch (mode) {
case 0x06: // display time
displayTime();
break;
case 0x04: // display hours
if (time[3]) displayTwiddle();
pause(BLINK_SPACE);
displayNum(time[2]);
break;
case 0x02: // increment minutes
displayNum(time[1]);
break;
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A (void) {
//P1OUT ^= 1;
time[0] = (time[0] + 1) % 60;
if (time[0] == 0) { // new minute
time[1] = (time[1] + 1) % 60;
if (time[1] == 0) { // new hour
time[2] = (time[2] + 1) % 12;
time[2] = time[2]?time[2]:12;
if (time[2] == 12) { // new AM/PM
time[3] = !time[3];
#pragma vector=PORT1_VECTOR
__interrupt void Port_1 (void) {
mode = P1IN & 0x06;
LPM1_EXIT; // Wake up the main loop
switch (mode) { // Needs debounce!
case 0x04:
time[3] = !time[3];
break;
case 0x02:
time[0] = 0;
break;
P1IFG = 0; // Clear int flag
void displayTime(void) {
if (time[3]) { // twiddle on PM
displayTwiddle();
pause(BLINK_SPACE);
pause(BLINK_SPACE);
void displayNum (int c) {
int i;
for (i=c/10; i; i--) {
P1OUT |= 0x40;
pause(BLINK_ON);
P1OUT &= ~0x40;
pause(BLINK_OFF);
if ((c%10) > 4) {
P1OUT |= 0x41;
pause(BLINK_ON);
P1OUT &= ~0x41;
pause(BLINK_OFF);
for (i=c%5; i; i--) {
P1OUT |= 0x1;
pause(BLINK_ON);
P1OUT &= ~0x1;
pause(BLINK_OFF);
P1OUT &= ~(0x41);
void displayTwiddle(void) {
int i;
for (i=0; i<2; i++) {
P1OUT |= 0x40;
P1OUT &= ~(0x01);
pause(BLINK_ON);
P1OUT |= 0x01;
P1OUT &= ~(0x40);
pause(BLINK_ON);
P1OUT &= ~(0x41);
void pause (int c) {
volatile unsigned int t = c;
do { t--;} while (t);
msp430-gcc -mmcu=msp430x2013 -S led.c
.file "led2.c"
.arch msp430f2013
.cpu 430
.mpy none
[B].text
.p2align 1,0
.global fun2
.type fun2,@function[/B]
* Function `fun2'
fun2:
push r4
mov r1, r4
add #2, r4
mov.b #3, &__P1OUT
pop r4
ret
[B].Lfe1:
.size fun2,.Lfe1-fun2
;; End of function
.p2align 1,0
.global fun
.type fun,@function
[/B]/***********************
* Function `fun'
fun:
push r4
mov r1, r4
add #2, r4
mov.b #2, &__P1OUT
pop r4
ret
[B].Lfe2:
.size fun,.Lfe2-fun
;; End of function
.section .init9,"ax",@progbits
.p2align 1,0
.global main
.type main,@function
* Function `main'
main:
mov r1, r4
add #2, r4
mov #23168, &__WDTCTL
mov.b #65, &__P1DIR
mov.b #1, &__P1OUT
call #fun
call #fun2
.L4:
jmp .L4
[B].Lfe3:
.size main,.Lfe3-main
;; End of function
[/B]
