Clock uncertainty in Synthesis and static timing analysis.
vid31
Junior Member level 2
I have started working on STA and Synthesis.
Can anyone help me how to predict values of clock uncertainty,clock transition,input transition,input/output delay,etc.?
I know that it depends on design as well as clock frequency but is there any relation between these values and clock period like clock uncertainity is 4% of clock period?
Every company has their own deisgn flow and design margin according their libarary.
So. If you want to do synthesis or pre-layout STA, you must follow that margin guider, for example, ZWLM, 55% clock cycle as shrink ratio.
And for input/output delay, you can make it tighten enough in order to make STA result better.
Reactions: vid31
    vid31
I'm also searching for that. I read in one tutorial in the internet that they use charaterize command in DC or refer to the datasheet for set_input/output_delay value.
Hairo
Reactions: vid31
    vid31
Thanks,
Hairo, would you provide me that tutorial....
Thanks,
Vid31
The clock uncertainty should also contain the jitter, if the clock generator is made by a collegue, just ask him the specification.
The duty cycle could also impact if you use both edges flip-flop design, from rise to fall and fall to rise, that "overconstraint" the clock max frequency if the duty cylce is 45%/55%.
@ rca,
but what value should be provided to overconstraint for 50% duty cycle clock?
Is there any convention in that?
Thanks,
vid31
Normally for i/o delays they do budgetting. Like say 70-30 if u dont get these from the top level designer.
Uncertainty would not be more than half cycle of ur clock. so max 50% of ur clock.
Clock transition u can set diff values and check how is ur insertion delay and skew. This value must be within the min and the max transition values.
Hi Vid31,
This is the tutorial I mentioned. Hope it helps you.
Best,
Hairo
  • Synthesis-flow.pdf
Does anyone know how to generate list of registers those are clocked by perticular clock?
I want the list of registers per clock domain.
Is there any command in design compiler?
Regards,
Vid31
Hello,
all_registers -clock <clock_name>
Reactions: vid31
    vid31
Hi oratie,
Thanks...
Thank you very much..
Regards,
vid31
