[SOLVED] 18F4550 bootloader problem
varunme
Advanced Member level 3
18F4550 when programmed with microchip bootloader firmware and used with
board , when connected to USB , message shows , usb device not recognized and shows unknown device in device manager , I am using K182 programmer from Kitsrus for programming the PIC , I didn't changed anything including fuse settings from the original bootloader , what can be the reason for not functioning ?
hi,
Try to check if the oscillator is on!
Measured on pins 13 and 14 and see if you have approximately 2V.
If you have not: change the 2 capacitor or the quartz.
Measured on pin 1 and see if you have 5V.
Reactions: varunme
    varunme
pin 13 is giving 0.98V and pin 14 is giving 2.14V and pin 1 is giving 1.64 V
Hi!
The voltage on pin 13 is not good ! change or verify c3 !
remove C15 and verify R1 ! On C1 you have 5 V ? On pin 1 you need to have 5V.
hi all,
varunme did you got it working? if yes, can you please let me also how you solved it.
members i am also having a similar kind on issue, if you wish please take a look at my issue also (https://www.edaboard.com/threads/224034/)
thanks
Not yet , devil6600 , i will definetly inform you dear once i rectify it :smile:
if you are using the same schematics as the one mentioned (olimex circuit), then I think you need to keep RB4 button pressed or short to ground while connecting the board to the USB port of PC. You need to burn the bootloader with a hardware programmer, later your could flash the chip with PDFUSB from microchip.
RB4 shorted at connection time and inconjunction with reset switch also tried
There are only few possibilities here:
1) USB D+/D- have been connected in reverse.
2) correct PIC driver has not been installed on PC
3) long shot boot loader has not been installed properly.
my hunch is no 1.
I cannot install the driver as i connect the board , message says unknown device
Hi!
C1 is giving 4.54V
---------- Post added at 09:32 ---------- Previous post was at 09:21 ----------
D+ and D- are fine
---------- Post added at 10:01 ---------- Previous post was at 09:32 ----------
the MCLR (pin1) now shows 5V (it was a mistake by me that the power adapter wasnt connected , now connected it and shows 5V in MCLR)
C3 changed , but the pin 13 , shows only 0.80V
in circuit C1 and R1 are fine, should i remove and check ?
thanks
Hi varunme,
What is the exact bootloader you are using? Can you provide a link to it on the Microchip Website?
BigDog
I tried almost all Bootloaders and the USB firmware without bootloader as well
from Microchip
thanks
varnme
Hi!
try to burn this : **broken link removed** ! if led blinking is good!
I have tried this and programs created by me to check each ports , all are working except the firmwares using USB
what is the value of capacitor you are using at vusb pin?
try the attached hex file, it should blink led on porta.0 (pin2) 5 times a second, this will confirm pic is running at proper speed.
  • test.zip
c5 marked as 0.1 and is disc capacitor , the code (attached) works correct
hi !
i attach a CCD Demo from MCHPFSUSB v2.2 USB Framework compiled and tested on mai board with 18f4550.
Please burn a "USB Device - CDC - Basic Demo - C18 - PICDEM FSUSB.hex"!
  • USB Device - CDC - Basic Demo.zip
