firblazer
Newbie level 3
Hi!
I want to test if my USB to RS232 converter works.
First, I connect the USB to RS232 converter to a laptop at the USB connector.
Next, I connect the RS232 connector port of the converter to a cross serial cable to another RS232 port of a computer.
Then, I start a software called Putty and run the serial section of the software for the laptop and the computer.
I have set it to 9600, 8 data bit, 1 stop bit, no parity and Flow Control to None.
Am I right to say that if I type something on the laptop and I should see it in Putty in the other computer and vice versa?
Right now, I am not getting output.
Is my setup correct?
Thanks.
Thanks.
