romel_emperado
Advanced Member level 2
- Joined
- Jul 23, 2009
- Messages
- 606
- Helped
- 45
- Reputation
- 132
- Reaction score
- 65
- Trophy points
- 1,318
- Location
- philippines
- Activity points
- 6,061
Hi I want to interface this shift register into a micro controller but I dont understand how to properly receive the output of this register.
http://www.datasheetcatalog.org/datasheet2/4/09499zog6et5i38fsd2w00grp8ky.pdf
Description:
yes I understand this part but Im confused about how the MCU receive it's output from it's parallel input.
it looks like a 1 wire method.. pls help
the register model is CD74HCT597
Description:
The ’HC597 and CD74HCT597 are high-speed silicon gate
CMOS devices that are pin-compatible with the LSTTL 597
devices. Each device consists of an 8-flip-flop input register
and an 8-bit parallel-in/serial-in, serial-out shift register. Each
register is controlled by its own clock. A “low” on the parallel
load input (PL) shifts parallel stored data asynchronously into
the shift register. A “low” master input (MR) clears the shift
register. Serial input data can also be synchronously shifted
through the shift register when PL is high.
