Simple code to read and write sle 4428
carduser1
Newbie level 1
Newbie level 1
Can someone provide an idiots guide to reading and writing a SLE-4428.
I would like to write a 6 digit number into the card, this number will be permanent.
Also would like to use a different portion of memory to hold a temporory number that will
not rmain after power down.
Is their a step by step process for this.
Actually anything on reading and writing would help.
what is the first step?
I have already established Hevse the reader the card, and software to communicate PCSC.
Anyone help is appreciated.
Thanks
JN:???:
Your SLE 4428 card has default PIN = FFFF.
First you need to verify PIN USING below COMMAND :-
FF 20 00 00 02 FFFF
Then you can write data to SLE 4428 card.
If data is "My name is Kashyap" then in hex it is 4D79206E616D65206973204B617368796170.
Write Data:-
FF D0 00 20 12 4D79206E616D65206973204B617368796170.
You can also change default PIN. Suppose I want to chagne PIN to 1234 from FFFF then
use below Command:-
FF D0 03 FD 03 FF 1234.
To read data below command:-
FF B0 00 20 12
Thanks,
Kashyap
Reactions: joebee
    joebee
Hello guys
I need to read and write SLE 4428 data in my .net application, for example to read a string stored in a memory location.
Is there any libraries available for .net platform?
Regards
