Reversing a binary number
navenmou
Full Member level 4
Full Member level 4
Bangalore, India
Hi all
I want to write a C program for reversing a binary number i.e like this 001101---->101100.....I am not getting idea on how to proceed....please give me some ideas for that....
Thanks in advance
Re: Revrsing a binary number
Here's a quick and efficient algorithm to reverse the ordering of a byte:
unsigned char rbyte = 0;
unsigned char byte = 0xAA; // 0xAA Represents Value to Be Reversed
int i;
for (i=0 ; i<4 ; i++)
rbyte |= ((byte & (1 << i)) << (7-2*i)) | ((byte & (1 << 7-i)) >> (7-2*i));
It works well.
BigDog
int i;
It works well.
BigDog
Another option would be
Code C - [expand]
int i;
for (i=0 ; i<8 ; i++)
    if (byte & (1<<i)) rbyte |= (1<<(7-i));
I have tested it in AVRstudio and it executes at about 20% less cpu cycles
Alex
If the bit reversal has to be carried out frequently in your code, a ROM table is the fastest solution, at least for 8 bit entities. For larger numbers, byte swap can be used in addition.
This is an example of the lookup method suggested by FvM applied to 8-bit char and 16-bit integer, the lookup table is used for each nibble (4-bits)
Code C - [expand]
8
9
10
11
12
13
14
15
unsigned char reverse_byte (unsigned char input_byte)
  const unsigned char lookup[16]={0,8,4,12,2,10,6,14,1,9,5,13,3,11,7,15}; // depending on the compiler use the proper keyword to make this a flash (ROM) variable
  return (lookup[input_byte & 15]<<4) | (lookup[input_byte>>4]);
unsigned int reverse_int (unsigned int input_int)
  return (lookup[input_int & 15]<<12) | (lookup[(input_int>>4) & 15]<<8) | (lookup[(input_int>>8) & 15]<<4) | (lookup[(input_int>>12)]);
Alex
Revrsing a binary number Tested in Codevision 100% work,By Saeedvand. :)
void revise_data(char byte)
unsigned char hbyte,lbyte,d; // 0xAA Represents Value to Be Reversed
char revise,Final_revise_data;
int i;
revise=0;
lbyte=(byte)%(0x10);
hbyte=byte-lbyte;
revise |= ((lbyte & (1 << i)) << (7-2*i)) | ((lbyte & (1 << 7-i)) >> (7-2*i));
lbyte=revise;
revise=0;
revise |= ((hbyte & (1 << i)) << (7-2*i)) | ((hbyte & (1 << 7-i)) >> (7-2*i));
hbyte=revise;
Final_revise_data=hbyte+lbyte;
