liling_03
Newbie level 3
Dear all,
Please help me!
Currently I am doing antenna design, Rectangular patch antenna with a novel coplanar waveguide fed diamond patch for UWB application, the ground layer and diamond patch are the same later on PCB, another layer of PCB have no copper plane.
The frequensy range required is 2.27GHz to 10.63GHz.
With my pre-design based on some reference design searched on web. I only able to obtain freq range of 4.5G to 10GHz (simulation result).
Below are some of my modification done, wrt the pre-design:
1) Increase distance of patch and ground plane->freq range: 3.5G-9.5GHz
2) Increase the board substrate(RT/duroid 5870 Er=2.33) thickness->freq range: 4.1G-9.9GHz.
Appreciate if you have any other idea on achieving the frequensy range hence to obtain higher impedence BW?
Regards/Lingling.
Please help me!
Regards/Lingling.
