Encounter Library Characterizer user guide ...
Oveis.Gharan
Full Member level 4
Full Member level 4
Iran
Hi Everybody.
Is there anyone who can share Encounter Library characterizer User Guide?
Thanks in advance.
Alireza
I cant share the ELC user guide with you, but may I be able to help you with questions you have regarding ELC?
Hi Eklikeroomys.
I am so glad that you declare your readiness to help me and answer my question about ELC.
No problem.
I could find ELC User Guide just now.
I am a newbie user in ELC.
Do you have any tutorial or a design flow example with ELC which could learn me the flow?
Thanks in advance.
Alireza
Yes, I do have a tutorial, though it is not very clear, but it helps you to get started. There is not a lot of information available regarding ELC, as you have probably noticed. See the attachment for a tutorial.
  • Cadence-ELC-Tutorial.pdf
Salaam again.
Do you know what is ELC counterpart in synopsys products.
Someone has said that it is "Liberty NCX". Is it realy true?
Thanks for your atttention.
BR
Alireza
I have my layout,,,
I am a newbie but just got Liberate and ELC installed... I checked the tutorial above.. am not clear as such as to feed what data and how.. can someone help me ???
I now went through the set of commands and executables but not getting of how to instantiate it... I dont know if any files or supporting directories, if so which, needs to added in PWD...
You need the following files in your working directory:
cmd_file (This optional file contains a list of ELC commands to execute in succession. Alternatively, you can interactively enter commands into ELC.)
elccfg (ELC configuration file. Specifies parameters to ELC)
spice_netlist.scs (SPICE netlist containing all circuits to be analyzed.)
setup.ss (This SPICE setup file tells your simulator how to simulate the circuits to be characterized.)
The user guide gives examples for each of these files.
Hope this helps.
