jayanthyk192
Full Member level 3
hi,
I building a brushless motor controller using h bridge. the upper side has irf9540 and the lower side has irfz44n. i connected their sources to 5thv and 0v resp. using logic 5v as gate voltage for both I started the brushless motor. it works but the current is not going beyond 200mA.why is this happening. the current at 5v for both is beyond 3A for both.
thank you
thank you
