Microwave, koch curve dipole antenna, ground
Sara88
Junior Member level 1
At the above attached image is my (layout design) of A single band dipole koch curve antenna operating in 850-900MHz..
I have two problems:
1) Do you think that i need a ground plane?
- I read some articles and said that (A ground plane is etched on the opposing side
of the dielectric layer from the radiating element)
-But other article, said ( no need for a ground plane because its a dipole different from monobole, but with two pieces of conductor)
2) I tried to draw the design in AWR microvave, but i'm struggling with the simulation and the return loss (S11) which i have to get at least -6dB.
#3) What do you think best suitable way to design "a single band dipole koch curve antenna with at least -6dB operating 850-900MHz
:oops:
hi
i am sorry but i think i should say some thing about the basic of antenna for all because many time i saw this question
"Do you think that i need a ground plane?"
every one know that the magnetic charge has dipole structure so every antenna imitated this and ground is the part of antenna which u connected it the negative polarity of source
so when u applied dipole structure how u can have another ground
1-when u applied a "one side dipole "structure you dont need another ground plane
2- awr result for antenna is not reliable so i suggested you to use HFSS
but u used a simple kind of antenna for this antenna u need folded kind so and u can find some model in here
https://www.edaboard.com/threads/217004/
any one know how i can design dipole anttena with metamaterial ground!!!!!!!!!!!!!!!!!from where should i start
