How to find theprogram size in keil
thannara123
Advanced Member level 5
Hi experts , I want to know the size of the my program written Keil (8051 Compact able ) ,How can i find it,any simple way to understand it ?
while compiling the code, Keil will display, code size & data size in output window
thanks for reply ,
Build target 'Target 1'
compiling g.c...
linking...
Program Size: data=9.0 xdata=0 code=53
"k" - 0 Error(s), 0 Warning(s).
how to ,or how to understand in Kilobyte or bite ?
I only work with small programs and allways get only bytes (without "k")
...but I think this is k=K=kilo (1024x) bytes..
p.s.
add some array:
unsigned char data arrayOfBytes[1000];
and you will see change in code size...
all the files generated by compiler like object , hex, and other files can be seen in the directory where it creates hex file... you can check the properties of it to find the size...
The filesize is not at all same as the code size, for example this is a 228 byte code which is written is a hex file of 664 bytes.
The hex file includes address info too and not just the code bytes.
:0400000012C0FECF5D
:10000400FDCFFCCFFBCFFACFF9CFF8CFF7CFF6CFA8
:10001400F5CFF4CFF3CFF2CF21C0F0CFEFCFEECFB7
:10002400EDCFF894EE27ECBBF1E0FBBFEBBFE5BFEF
:10003400F8E1F1BDE1BD8DE0A2E0BB27ED938A9527
:10004400E9F780E094E0A0E6ED930197E9F7EFE5A6
:10005400EDBFE4E0EEBFC0E6D1E01AC08A93AA93F4
:10006400EA93EFB7EA93E5B1E8BBA0E09099A1E089
:10007400E1E0EA2711F4909801C0909A8BE18A9507
:10008400F1F7369AE991EFBFE991A9918991189511
:10009400E0E0E8BBEFEFE7BBE0E0E5BBE4BBE2BBDD
:1000A400EFEFE1BBE0E0E3BFE2BFEFBDEEBDEDBDCE
:1000B400ECBDE7BDE6BDEBBDEABDE9BDE8BDE2BD13
:1000C400E5BDE4BDE3BDE5BFE9BFE0E8E8B9E0E0D4
:1000D400E0BFE0E6E7B9EEECE6B97894FFCFFFCFF6
:00000001FF
The correct sizes can only be viewed in the compiler report screen or maybe a compiler log file
Alex
