grizedale
Advanced Member level 3
Here is an 800W offline SMPS with no power factor correction.
-How can this amp possibly last?
The diode bridge current peaks must be sky-high.
Also, even though there's 1.36mF of capacitance after the mains didoe bridge, surely the input ripple current will stress that capacitance at 800W input.
Surely it would have been better to do away with the selection switch which selects 120VAC or 240VAC, and just put a simple boost converter at the front end, with a 400V output?.........it wouldn''t even have to be properly power factor corrected.
And would you say that it looks liek an LLC resonant converter?
