karthiga05
Member level 2
hi guys. im currently doing a 4-bit up counter using hierarchical desgin. i have to onclude my half adder and/or fulladder in my design. but im unsure if the ones in red is correct. Also, im not sure abt how to do the port mapping. would really appreciate your help. thanks!
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity counter is
port(countut std_logic_vector(3 downto 0);
clk:in std_logic;
reset:in std_logic);
end counter;
architecture behav_counter of ha is
component ha port (a: in std_logic;
b: in std_logic;
sum: out std_logic;
c_out: out std_logic);
end component;
signal a_in: std_logic_vector(3 downto 0);
signal b_in: std_logic_vector(3 downto 0);
signal c: std_logic_vector(3 downto 0);
signal cout: std_logic_vector(3 downto 0);
begin
counterrocess(clk, reset)
begin
if reset'event and (reset = '1') then
c <= (others => '0');
--If RESET changes (reset'event), and RESET is now HIGH '1', then the output (c_out) is set to all zeroes.
elsif clk'event and (clk='1') then
--If CLK changes, and CLK is now HIGH '1', then perform the addition below.
ha1 : ha port map(a => a_in(3), b => b_in(3), sum => c(3));
ha2 : ha port map(a => a_in(2), b => b_in(2), sum => );
end if;
end process;
count <= c;
end behav_counter;
---------- Post added at 11:11 ---------- Previous post was at 10:53 ----------
begin
ha1 : ha port map(a => a_in, b => b_in, sum => c(3));
ha2 : ha port map(a => c(3), b => b_in, sum => c(2) );
ha3 : ha port map(a => c(2), b => b_in, sum => c(1) );
ha4 : ha port map(a => c(1), b => b_in, sum => c(0) );
end if;
end process;
OR is this correct?
library ieee;
entity counter is
clk:in std_logic;
end counter;
b: in std_logic;
sum: out std_logic;
end component;
begin
begin
end if;
end process;
count <= c;
end behav_counter;
begin
end if;
end process;
OR is this correct?
