[SOLVED] matlab help+envelope of a signal
sayfee
Junior Member level 1
say i have signal
a=[1 1 2 3 1 2 3];
i want to plot the envelope of this signal, how to do that in matlab?
thank you in advance.
These are few points to graph a good envelope.
For a general case use the Hilbert transform.
ht = hilbert(a) ; plot(abs(ht))
Reactions: sayfee
    sayfee
the envelope isnt following the massage..can u suggest me another code which follows accurately ??
thank you for your reply
But what is the definition of envelope you use?.
When you have a few points is not as intuitive as it is in a typical AM signal
The general definition is the modulus of the analytic signal, which is the value returned by the function hilbert ()
ok i need something like this:eboard2.JPG
i draw the picture so the lines are not strait.
the problem is sloved,
all i have to do is
plot(a),hold on
stem(a)
thank you sir for your cooperation
