MQ2 Combustible Gas sensor circuit
demetal
Full Member level 5
Full Member level 5
Kingdom Of Kochi
i want to built a Combustible gas sensor circuit using the 6 pin gas sensor MQ2 (winsen)... to interface with microcontroller... now i only want to operate a relay without using a microcontroller...
I dont know how to connect the pins... if any one have schematic please help.....
Thankyou.
  • MQ2 Datasheet.pdf
Read the datasheet:
The sensor need to be put 2 voltage:
heater voltage(VH) and test voltage(VC).
VH used to supply certified working temperature to the sensor, while VC used to detect voltage (VRL) on load resistance (RL)whom is in series with sensor. The sensor has light polarity, Vc need DC
power. VC and VH could use same power circuit with precondition to assure performance of sensor. In order to make the sensor with better performance,
suitable RL value is needed: Power of Sensitivity body(Ps):
Ps=Vc2×Rs/(Rs+RL)2
Vh=5V
---------- Post added at 12:17 ---------- Previous post was at 12:14 ----------
