generating analog voltage using microcontroller
aruna1
Member level 1
Member level 1
Hi
I need to generate an analog voltage using a microcontroller (16F877A)
I have two options -
1.)Use R-2R ladder and make a 10bit DAC
2.)generate 1kHz PWM signal-->send it through a 6 pole lowpass filter-->get analog voltage relevant to duty cycle.
Since I couldn't find any DAC ics, I'm stuck with above two options (they are the only methods I know of, are there any other methods?)
I have to order some DAC ICs but it will take about 3 weeks to reach me, so untill then I have to use some method to generate voltage?
What method do you think most reliable? that is more accurate and steady?
Thank you
For second method, L C filter can be used for stable voltage.
Here is two simple examples.....................
KAK
KAK
ya I know the method, infact it is what i stated as my second option.
You don't need to generate PWM signal. Just generate a square signal of frequency 1KHz, then filter-out using a 4th order active filter to get a faithful sine wave. We are doing this form of simple analog voltage generator.
Yes. It provides better efficiency if the analog signal need big driving capability.
how could a sine wave help in my requirement? I think you misunderstood what I was saying.
Aruna,
If your range is 0 to 5V, you can use a DAC like MCP4912 (Microchip) which can be written through SPI. If you need higher voltage at the output, the DAC output can be amplified by a non inverting amplifier.
In case you dont want to use a DAC, you can generate a PWM, and connect a RC low pass filter to get a linear output voltage. ensure the RC time constant is greater than your PWM cycle time, otherwise you may end up getting a triangular wave.
Using a DAC will give you more accuracy. Hope this helps.
Regards,
JayantD
I ordered a sample DAC from TI and it will arrive next week. after all I will not need PWM :)
thank you all
